Right, I'm in!
Please talk me through resetting the ip addy as it doesn't seem as straightforward as suggested :)
It's saying 'Lease time 1 day, is that correct?
Plus IP address 192.168.0. 2. To 254
Right, I'm in!
I've just thought, I should say it's the remotes that I use (Ipeng ) on my iPad and iPhone that are 'losing' the Squeezebox! :(, I can still use the supplied remote and it works fine.
Sorry if I have been misleading anyone!
It's because the player addresses are going walkabout that you're having problems.
If the player IPs remain constant the devices with the apps don't have to look for the players.
With the "I'm in" comment I take it you used the username and password I posted?
Do those details I've posted make any sense to you Chris?
Mine only asks me for the password, so that sounds about right.
So you go to advanced settings, scroll down until you get DHCP reservation and click on that.
You get a list of devices on the network, with a tick box next to each device. Tick the box next to your first player, then click on add reservation. Repeat for the other player.
When you scroll further down the page you should see each player with reserved next to it.
That's about all there is to it.
Don't forget to change your password, and take note of it.
I'll try it as soon as I get home.
It's saying the numbers I've typed in are not n the DHCP range!
Help!
I've come over all nostalgic, it's bought a slight tear to my eye :(
