That is a whole lot of amp for the money.
Gumtree so only if you are local to Stroud but Lenco GL75 for £45.
https://www.gumtree.com/p/other-ster...l15/1209693072
Thanks for heads up Sean - I've contacted the seller so here's hoping.
I see neither Anthony nor indeed Marco has come on to talk about this one so I thought I'd attempt to provide some context here ... this is not one of Anthony's famous ground up creations (aka 'Copper Amp'), rather it's one of several Tube Distrinctions/AoS branded, modified versions of Chinese-made amps. That's not to say it isn't good, but while it uses some of Anthony's mods to the circuit, it still uses the original Chinese transformers and is therefore ultimately limited in what it can do.
I had one of Anthony's modded amps for a while (actually a modded Puresound P30) and it actualy saw off some serious competition ... this was not the same as this one listed on ebay - though I have heard one of this design and considered the one I had to be quite a bit better ... but while good, a Copper Amp it most certainly wasn't. (Copper amp is probably £5k plus - and you get what you pay for).
I think the price in this listing is ambitious I'd be looking about £750 sort of mark for this one if I was going for it. Something to bear in mind.
Toshiba SR 370 without arm £116 including postage.
Look at this on eBay http://www.ebay.co.uk/itm/332089202852
I'm tempted but don't need it lol
