It may be placebo, but it seems better since swapping the noisy valve.
Just to add to the above -
Just sat through JC From Folsom Prison, JC From San Quentin and now Kraftwerk Autobahn and there is definitely a massive improvement, it can only have been that duff valve, I'm not sure how it effected vinyl more than digital but it can only be that.
I'm now looking forward to trying both a step up into the MM stage in the Luxman and a new cart at some stage as I don't think the Apheta is up to much if I'm honest.
With regard to HiFi, the best digital has the dynamic contrast & 3D soundstage (and subjective 'naturalness') of good analogue, and the best analogue has the precision & neutrality of good digital.
...big problem is there's a lot of better masterings out there on old vinyl, sometimes vice-versa (more so now with digitally remastered vinyl), making the CD / vinyl argument rather moot in a lot of cases.
I think he lowest note on a pipe organ is 8Hz but only a few can do it. The Atlantic City one for example. But a vinyl LP won't do 16hz, no matter how much you spend on equipment. You will only hear the harmonic, in mono.
Not true, there are systems that will go that low. The celestions I used to have had output down below 20 hz. Not flat but useful output still. There are subwoofer designs that will run flat down to that level. You need a few thousand watts of course but power is cheap these days.
You won't hear it but you will feel it. When I had the KEF 107's I would sit there marvelling at the how my body, sofa, doors etc were vibrating like buggery but I couldn't hear owt.
18hz - wonderful.
Adey
Sent from my Aquaris E4.5 using Tapatalk
