Less bright/toppy
No plugs just tinned ends for me dudes. With Fisual S-Flex 'studio grade' speaker cable. Good and cheap, my favourite things.
Although my speakers use those super high fidelity ultra modern Bulgin plugs and sockets!
Arden MkIIs but had same experience with DC10Ts.
Speaking as an ex-dealer -and it's probably worse now!!!
Dealers make a bloody fortune on speaker cables as it's usually a give-away on a system! If you're happy with this, then fine (and in fact, Naim and Rega cables possibly carry least dealer margin of all retailer bought wires).
I use an electrical installation cable H-07, which is 7 strands at 2.5mm overall cross-section, two conductors per channel. May be not as cheap as the Fisual or Van Damme stranded 2.5mm, but it works well for me. The NVA LS2 uses a very good example of the cable and is neatly terminated with 'Z Plugs' which I like and use myself as long as they're not plugged and unplugged constantly..
One last shot - Linn marketed a very good speaker cable for the Classik one-box system they did. It still lives on
http://www.audioaffair.co.uk/linn-k1...CABEgLZUvD_BwE.
This stuff has been around for decades, is available from several suppliers for not huge money and is a fairly chunky transparent multi-strand figure-8 type with a thick red band down one side. I'm hoping the types available are the same and the typical one of old worked well with anything.
Thanks for that, loads of food for thought. Any evidence that the width of speaker cable enhances the bass?
Steer clear of screw on plugs! Differences as the screw loosens and or the contact area oxidises will completely out weigh the non existent differences between speaker cables.
About 20 years ago when I purchased a 'real' CD player (a Micromega) I asked the dealer to recommend/sell me some reasonable cable which I took (quad qlscf2). Still using them today. Via friends I have tried out various ultra expensive cables, mine beats or matches the ultra expensive cables. So now I don't focus on upgrading my cable.
