https://scontent-lhr3-1.xx.fbcdn.net...68&oe=58C772EF
Pictures showing a classic ATC Soft Dome Monitoring - Friends around the world (special limited edition print) poster signed by ATC's founder and chief engineer Billy Woodman on display here at Musicraft (Derby). This classic ATC poster is number 66/100 and was kindly given to us by one of our clients from Manchester who uses an ATC multi channel monitoring system which comprises of SCM40 passive, C3C passive, SCM11 passive and a C2 active subwoofer.
My stand out client from this classic ATC poster is The Pope. Which ATC client stand outs for you?
https://scontent-lhr3-1.xx.fbcdn.net...7f&oe=594A4517
https://scontent-lhr3-1.xx.fbcdn.net...47&oe=590B8BC7
https://scontent-lhr3-1.xx.fbcdn.net...ec&oe=590C72C2
https://scontent-lhr3-1.xx.fbcdn.net...39&oe=590C1D47
https://scontent-lhr3-1.xx.fbcdn.net...63&oe=594B90C0
https://scontent-lhr3-1.xx.fbcdn.net...97&oe=5945D5B2
http://atcforums.co.uk/product%20ima...Units%2004.jpg
ATC SM75-150 Soft Dome mid range drive unit
http://atcforums.co.uk/product%20ima...Units%2003.jpg
ATC SM75-150S Super Soft Dome mid range drive unit
http://atcloudspeakers.co.uk/wp-cont...llyWoodman.jpg
ATC, Acoustic Transducer Company, is a specialist British manufacturer of loudspeaker drive units and complete sound reproduction systems, including the relevant electronic equipment. ATC designs and manufactures the finest and most accurate of monitors in the world. ATC achieves this by designing and manufacturing loudspeaker drive units and systems to achieve levels of performance far in excess of the industry norm. ATC has kept to its aims of building loudspeakers and electronics which employ the most effective of modern engineering principles. ATC don't respond to competition, instead ATC responds to advances in technology that enables ATC to improve their products. ATC's goal is to have loudspeakers as near perfection in performance as possible by having the lowest possible distortion.
By selecting ATC you join a group of music lovers, professional audio engineers, educators, studios, and musicians across the world that understand the value of the engineering that goes into every ATC product.
ATC’s products are installed at some of the world’s most prestigious multi-channel studios and auditoria. Where ever the best is required you will find ATC.
http://vimeo.com/107575611?from=outro-embed (ATC's 40th Anniversary Celebration video)
http://atcforums.co.uk/pdf/ATC%20CORP%20BROCHURE.pdf (ATC Corporate brochure)
https://scontent-lht6-1.xx.fbcdn.net...df&oe=58E34D51
ATC Soft Dome Monitoring. The sound of accuracy. Naturally.
***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
A classic ATC Soft Dome Monitoring - Friends around the world (special limited edition print) poster 66/100 signed by ATC's founder and chief engineer Billy Woodman on display here at Musicraft (Derby).
Pictures showing ATC testing and completing the build of curved SCM19 passive monitors for one of our clients in Ireland
https://scontent-lhr3-1.xx.fbcdn.net...54&oe=59325E67
https://scontent-lhr3-1.xx.fbcdn.net...2a&oe=59297AD5
https://scontent-lhr3-1.xx.fbcdn.net...f7&oe=592FBC32
http://www.atcloudspeakers.co.uk/wp-...0796346708.jpg
ATC curved SCM19 passive monitors in Cherry finish
Featuring the new ATC designed and built 25mm soft dome tweeter, updated bass/mid drivers and crossovers housed in a curved, laminated cabinet, the first of a new range of ATC closed-box passive loudspeakers has arrived. The second generation SCM19 employs ATC’s landmark SH25-76 tweeter, developed to satisfy the company’s long-established rigour in drive unit engineering.
ATC Transducer. The sound of accuracy. Naturally.
http://www.whathifi.com/atc/scm19/review
ATC curved SCM19 passive monitors - What Hi-Fi Award Winner 2016 for the best standmount speaker £1500+
“If you value insight and honesty above all else, these speakers are a terrific buy”
http://atcloudspeakers.co.uk/wp-cont...te-600x944.png
ATC curved SCM19 passive monitors in Satin White finish
http://atcloudspeakers.co.uk/wp-cont...-1-600x944.png
ATC curved SCM19 passive monitors in Satin Black finish
ATC SH25-76 HF Unit
Sharing technology with the renowned ATC Soft Domed mid-range drive unit, the new tweeter employs a unique dual suspension system suppressing rocking modes even at high power output levels. The ATC configuration of a short edge-wound voice coil in a long, narrow magnetic gap ensures exceptionally low distortion throughout its operating band and removes the need for ferrofluids, which can dry out over time, compromising performance.
A complex, shaped, soft-domed diaphragm extends high frequency range and offers a smooth off-axis response. The tweeter’s 15,000 gauss (1.5 tesla) neodymium magnet has a black heat-treated top plate, which dissipates heat away from the voice coil to maintain high power handling and low power compression. A precision-machined 5.5mm rigid alloy waveguide provides optimum dispersion, a flat on-axis frequency response and resonance-free operation.
http://www.atcloudspeakers.co.uk/wp-...7797865192.jpg
ATC SH25-76 HF Unit used in curved SCM19 passive monitors
https://scontent-ams3-1.xx.fbcdn.net...d3&oe=58C5C126
ATC's security guard
ATC’s SH25-76 soft dome tweeter is joined by the company’s highly linear 150mm mid/bass driver. It features an integrated 75mm soft dome – exceptional for its horizontal dispersion of mid-band frequencies – and a huge 9kg high-energy, ‘Super Linear’ magnet system, which includes a 75mm diameter flat wire, underhung voice coil, meticulously milled and formed by ATC. The magnet system and a carefully weighted doped fabric cone assembly contribute to the SCM19’s wide bandwidth, impressive dynamic range and convincing bass output coupled with very low distortion as a result of the unique ‘Super Linear’ motor system.
http://atcforums.co.uk/product%20ima...001%20edit.jpg
ATC SB75-150 SL mid/bass drive unit used in curved SCM19 monitors
Second Generation SCM19 - New Cabinets and Systems
Establishing what is to be a new style for ATC’s most competitively priced range of loudspeakers, the new SCM19's benefit acoustically and aesthetically from a curved cabinet construction. Braced and laminated for high rigidity and damping, the curved enclosures in real cherry or black ash veneer also impart a strong impression of design quality. Improved crossovers featuring metallised polypropylene capacitors, large air cored inductors and ceramic wire-round resistors offer superior power handling and clarity. The SCM19 exhibit an impedance curve free from low values, presenting an easy load for amplifiers of 75 to 300 watts. The SCM19 is designed for optimum performance with the grill in place – although the difference in performance without the grill is minimal. The metal grille, finished in anthracite grey, fixes to the cabinet via hidden magnets. According to tradition, each model number represents internal cabinet volume in litres.
ATC curved SCM19 passive monitors RRP £1996/pair
https://scontent-lhr3-1.xx.fbcdn.net...2d&oe=5905FA00
ATC SCM100ASL Professional Monitors used here at Musicraft (Derby)
https://scontent-lhr3-1.xx.fbcdn.net...d0&oe=58AB7F3E
http://atcloudspeakers.co.uk/wp-cont...100ASL-Pro.png
ATC SCM100ASL Professional monitors
***** Musicraft website - Special Offers list http://ww.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
SweetwaterSound interviews ATC R&D engineer Ben Lilly
https://www.youtube.com/watch?v=R9hPO1417ik
ATC Professional. Reference monitoring. Naturally.
https://scontent-lhr3-1.xx.fbcdn.net...56&oe=5973C2F4
Thanks
Rick @ Musicraft
A freshly built pair of ATC SCM200ASL Professional monitors for Helios Pro Audio Solutions, Haarlem, Netherlands.
https://external-lhr3-1.xx.fbcdn.net...AQ5nq2wol7r_V8
http://atcloudspeakers.co.uk/wp-cont...200ASL-Pro.png
http://atcloudspeakers.co.uk/wp-cont.../11/p4-amp.png
ATC P4 rack-mount grounded source 850W class A/B amplifier used with SCM200ASL Professional monitors
http://atcforums.co.uk/otherimages/image001.jpg
ATC SH34-76 Super Soft Dome HF drive unit used in SCM200ASL Professional monitors
http://atcforums.co.uk/otherimages/image002.jpg
http://www.atcloudspeakers.co.uk/wp-..._Web_Large.jpg
ATC Super SH34-76 HF unit & ATC SM75-150S Super Soft Dome mid range drive unit used in SCM200ASL Professional monitors
http://atcforums.co.uk/product%20ima...Units%2009.jpg
ATC SB75-314(SC) SL bass driver used in SCM200ASL Professional monitors
Thanks
Rick @ Musicraft
Thanks
Rick @ Musicraft
Hi-Fi News (March 2017) reviews ATC's new P2 300w/ch dual mono power stereo power amplifier
http://atcloudspeakers.co.uk/wp-cont...eprint-LOW.pdf
“the P2 is one of those subtle components that quietly works its magic on you, until you suddenly realise that it is doing everything brilliantly but without any fuss or melodrama. Put simply, it just sounds ‘right’.”
“In terms of detail, the P2 struck gold once again. Instruments were lifelike and beautifully atmospheric, no matter whether a recording featured a soft solo acoustic ensemble or a grand orchestral bombardment.”
Adam Smith, Hi-Fi News, March 2017
Generating twice the power of its smaller P1 sibling, the P2 will drive the most challenging loudspeakers with ATC’s signature virtues of wide bandwidth and ultra-low distortion…
http://atcloudspeakers.co.uk/wp-cont...hifi-front.jpg
ATC's new P2 300w/ch dual mono power stereo power amplifier is at Musicraft (Derby)
https://scontent-lht6-1.xx.fbcdn.net...99&oe=58F63E67
ATC P2 power amp modules
https://scontent-lht6-1.xx.fbcdn.net...6c&oe=58E78665
Musicraft's new P2 300w/ch dual mono power stereo power amplifier at ATC
https://scontent-lht6-1.xx.fbcdn.net...d3&oe=58E10D81
https://scontent-lht6-1.xx.fbcdn.net...6e&oe=58FD2F24
https://scontent-lht6-1.xx.fbcdn.net...1e&oe=58F7CF3E
http://atcloudspeakers.co.uk/wp-cont...-hifi-rear.jpg
http://atcloudspeakers.co.uk/wp-cont...Fi-3-4-Sml.jpg
http://atcloudspeakers.co.uk/wp-cont...10/p2-hifi.png
Hand-built by ATC in the UK, the P2 class A/B stereo power amplifier is designed to complement the brand’s range of hi-fi preamplifiers, both aesthetically and operationally. Rated at 300W continuous power per channel and developed in tandem with the P2 Pro studio amplifier, the ATC P2 is a Dual Mono design, keeping the power supplies, signal and return paths discreet. This approach ensures that the amplifier will achieve the maximum signal separation with minimal crosstalk, and that intermodulation between channels via the power supplies is reduced to an absolute minimum across a frequency range of 400kHz. It also means that the power delivery from one channel cannot affect the specified power available from the other.
Within a new low-vibration chassis design featuring a precision machined 12.7mm brushed aluminium front panel, the P2’s layout includes a massive, custom-made 400 VA low-noise transformer for each channel and an output stage involving 3 pairs of MOSFET devices per channel to achieve peak current output of over 15 amps. ATC’s unique “grounded source” output stage ensures smooth power delivery and extremely low harmonic distortion. The gain of the P2 matches that of the lower power P1 (150W/ch) so that they can be used together in bi-amp or tri-amp systems, connected via the amplifier ‘Link’ phono inputs/outputs.
The ATC P2 offers balanced XLR and unbalanced phono inputs, ‘link’ phono outputs, proprietary 4mm speaker terminals, and IR remote control.
ATC P2 Features -
• Latest ATC discrete MOSFET grounded source output stage.
• Class A/B topology.
• 300W into 8 ohm continuous power O/P capability
• Dual mono-design ensures minimal crosstalk and inter-channel modulation.
• Entirely separate power supplies for high voltage audio, low voltage audio and logic/control.
• 400kHz bandwidth to ensure best possible transient reproduction.
• Vanishingly low distortion.
• Custom low noise toroidal transformers.
• New chassis design for reduced vibration and a more striking visual appearance.
ATC P2 Specifications -
• Max Continuous Output Power : 300W (8Ω, 1% THD)
• Input Sensitivity : 2V rms (ref. 150W out)
• Input Impedance : 10kΩ/leg
• Frequency Response : <2Hz – >400kHz (-3dB)
• Signal to Noise Ratio : >110dB (DIN)
• Crosstalk : >100dB
• THD : >0.002%/-95dB
• Dimensions (HxWxD) : 141x448x337mm (5.6˝x17.6˝x13.3˝)
• Weight : 30kg / 66lbs
• 6 year warranty
ATC P2 RRP £3120
Thanks
Rick @ Musicraft
https://scontent-lhr3-1.xx.fbcdn.net...9b&oe=5905098A
The Speaker Shack reviews ATC's SCM19AT SL Active Tower monitors
https://www.speakershack.co.uk/artic...=1&record=1729
http://atcloudspeakers.co.uk/wp-cont...02/scm19a1.png
The SCM19AT system is an active version of the Company’s SCM19 award-winner, uniting proprietary, optimised driver/amp pairings in a slender floor standing design…
http://www.the-ear.net/review-hardwa...ve-loudspeaker
The Ear reviews ATC's SCM19AT SL Active Tower monitors
"I could go on but hopefully the crux has been communicated, this ATC like its range mates is not designed to elaborate on the signal, it exists to let you hear it like it is. In this respect it sounds more like a studio monitor than your average domestic loudspeaker and what this does is focus on the playing, singing and performance rather than the sound. So ATCs are speakers for music junkies, especially those who like their music at the same sort of sound pressure levels enjoyed by many musicians. They are a blank canvas at the mercy of the signal, get that right and you have an unusually good loudspeaker, one that will keep you enthralled to the end of every album."
Positive Feedback reviews ATC's new SCM19AT SL Active Tower monitors
http://positive-feedback.com/reviews...peaker-system/
“…also takes a company with diverse engineering expertise to cover electronics, mechanics, electro-mechanics, and other disciplines and this is rare. ATC clearly has the engineering talent required as they have been in business over 40 years and producing active speakers for many of them. The SCM19ATs are a wonderful advancement in the state of the art of active loudspeakers. You could easily spend three times as much on comparable separate components and not do as well. I strongly encourage you to seek out the ATCs and give them a listen.”
Michael Wechsberg | Positive Feedback 09-06-2016 | | Issue 87
http://hifipig.com/atc-scm19a-active-loudspeakers/
Hi-Fi Pig reviews ATC's new SCM19AT SL Active Tower monitors
Hi-Fi Choice reviews ATC's new SCM19AT SL Active Tower monitors
"Clearly shot through with the solid engineering and acoustic expertise loved by fans of ATC around the world, the SCM19A is an important and effective addition to the company’s extensive domestic line up. Used in anger with high octane rock it will make most similarly sized passive floorstanders sound somewhat flat and loose. But it does the delicate stuff with great care and finesse as well. A better advert for properly implemented active design at a relatively sane price I’ve yet to hear.”
David Vivian, Hi-Fi Choice August 2016.
ATC Loudspeaker Technology’s new SCM19 Active Tower SL speaker system will deliver the company’s reference-quality audio from an elegantly curved floor-standing design, just 370mm wide and under a metre in height. Identical acoustically to ATC’s award-winning passive SCM19SL 2-way system but utilising the 19 litre volume in a slim tower format, the SCM19AT SL combines high aesthetic appeal with the widely acknowledged performance benefits of ATC active design to create a compelling speaker proposition for music lovers.
The SCM19AT SL’s braced, sealed and curved multi-layer laminated cabinet, which is precision-finished in cherry or black ash real-wood veneer, provides a rigid and optimally damped environment for the Company’s acclaimed SH25-76 Soft Dome tweeter and 150mm Super-Linear mid/bass driver. Drive units are individually powered by an upgraded bi-amp pack (also proprietary), comprising ATC’s discrete MOSFET Class A/B modules, providing 32W of continuous power to the HF section and 150W to the bass.
ATC SH25-76 Tweeter
Sharing technology with the renowned ATC Soft Domed mid-range drive unit, the SCM19AT SL's tweeter employs a unique dual suspension system, designed to suppress rocking modes even at high power output levels. The ATC configuration of a short edge-wound voice coil in a long, narrow magnetic gap ensures exceptionally low distortion throughout the tweeter’s operating band and removes the need for ferrofluids, which can dry out over time, compromising performance. A complex-shaped, soft-domed diaphragm extends high frequency range and offers a smooth off-axis response. The tweeter’s 15,000 gauss (1.5 tesla) neodymium magnet has a black heat-treated top plate, which dissipates heat away from the voice coil to maintain high power handling and low power compression. A precision-machined 5.5mm rigid alloy waveguide provides optimum dispersion with a flat on-axis frequency response and resonance-free operation.
ATC SH25-76 HF Unit used in curved SCM19AT SL active monitors
https://scontent-lht6-1.xx.fbcdn.net...66&oe=596DFE6D
ATC SB75-150 SL mid/bass driver
The SCM19AT SL’s 150mm ATC SL mid/bass driver utilises a carefully weighted doped fabric cone with a 75mm soft dome – exceptional for its broad and even dispersion of mid-band frequencies. The cone is driven by an ‘under-hung’ (short coil/long gap) motor using a huge 9kg ‘Super Linear’ magnet system, which is unique to ATC loudspeaker systems. The 75mm ribbon wire voice coil is meticulously milled and wound in-house by ATC. ATC’s familiar under-hung motor topology maintains linear coil force and inductance, even at high drive levels, keeping distortion low.
ATC SB75-150 SL mid/bass drive unit used in curved SCM19AT SL active monitors
Electronics
The SCM19AT SL’s proprietary two-way on-board amp pack design has been revised to reduce noise and distortion (a further -10dB @ 10kHz), while achieving a lower operating temperature for improved reliability. The design includes protection circuits for both DC offset and thermal overload. Mid frequency THD is vanishingly low at 93dB/0.002%, and a very wide bandwidth of 200 kHz ensures the accurate reproduction of musical transients. ATC’s Grounded Source output stage modules are fed by a newly developed two-way active crossover section featuring 2nd order modified Butterworth circuitry with phase compensation for each crossover point. The advantage of active crossovers is that their response remains unaffected by variable voice coil impedance, while the use of phase compensation enables phase coherency at the crossover points, improving the SCM19AT SL’s tonal balance and enhancing imaging for a pin-point stereo field. As usual system input is via balanced XLR.
The ATC SCM19AT SL – the first active 19 in the Company’s history – is designed for optimum performance with the grille attached, although the difference in performance without the grill is minimal. Finished in anthracite grey, the metal grille fixes to the cabinet via hidden magnets. Designed and manufactured by ATC entirely in-house, the SCM19AT SL offers the ownership of a hand-built ruggedly engineered speaker system, world famous for musical accuracy and high power output. Like all ATC products, the SCM19AT SL is backed by a six-year warranty.
Features
• New ATC designed and built dual suspension 25mm Soft Dome HF unit with precision alloy wave guide
• “SL” spec bass driver with 75mm integral Soft Dome
• 9kg optimised short-coil/long gap motor assembly
• On-board grounded source 182 watt Class A/B Bi-amplifier
• Active filters and overload protection
• 6 year warranty
Specification
• Drivers: HF ATC 25mm dual suspension Tweeter, Mid/LF ATC 150mm SL
• Matched Response: +/- 0.5dB
• Frequency Response (-6dB): 54Hz-22kHz
• Dispersion: ±80° Coherent Horizontal, ±10° Coherent Vertical
• Max SPL: 108dB
• Crossover Frequency: 2.5kHz
• Connectors: Male XLR
• Input sensitivity: 1V
• Filters: 2nd Order critically damped with phase compensation
• Overload Protection: Active FET momentary gain reduction
• Fault Protection: DC fault protection and thermal trip. Fault indication on rear panel mounted LED
• Amplifier Output: 150W LF, 32W HF
• Cabinet Dimensions (HxWxD): 980x370x344mm (spikes add 25mm to height, grill adds 34mm to depth)
• Weight: 31kg/68.2lbs.
The advantages of active operation
• Perfectly matched dedicated amplifiers for each frequency band
• Active crossover filters with phase correction ensure accurate timbre, excellent imaging and source location
• A flat magnitude response that is not changed with power input level
• A 20dB improvement in intermodulation distortion
• Better controlled low frequency
• A greater dynamic range for the same input power
SCM19AT SL RRP £4990/pair
***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...sicraft-(Derby) *****
Thanks
Rick @ Musicraft
ATC SH25-76 Tweeter
Electronics
Features
• 6 year warranty
Specification
• Max SPL: 108dB
Thanks
Rick @ Musicraft
ATC SCM150ASL Professional monitors - hot off the production line.
https://scontent-lhr3-1.xx.fbcdn.net...cf&oe=595EC6DA
http://atcloudspeakers.co.uk/wp-cont...150ASL-Pro.png
https://scontent-lht6-1.xx.fbcdn.net...d0&oe=58E6A571
ATC Super SH25-76S Super Soft Dome tweeter used in SCM150ASL Professional monitors
Building on the success of its hand-built standard tweeter, ATC has developed and manufactured an ENHANCED ‘S-SPEC’ VERSION for its flagship models.
After considerable development time the “S-SPEC’ tweeter completes the rollout of proprietary drivers across every ATC loudspeaker system. Six years in the making, the new SH25-76S design is a significant technical advance for ATC and a proud achievement for Managing Director Billy Woodman and R&D Manager Richard Newman. The Woodman/Newman collaboration has ensured that both the standard SH25-76 (as fitted to the Company’s curved SCM7/11/19/40/40A models) and ‘S-Spec’ SH25-76S tweeters exceed the exceptionally high levels of performance and consistency expected of an ATC driver.
https://scontent-lht6-1.xx.fbcdn.net...27&oe=591FB1ED
ATC Super SH25-76S Soft Dome tweeter used in SCM150ASL Professional monitors
The advent of the SH25-76S means that for the first time in a distinguished forty-year history, every ATC speaker system is able to benefit from complete ATC driver configurations, wholly designed and hand-built at the company’s UK development and production facility at Stroud, Gloucestershire. Now introduced on the Tower Series (SCM20/50/100/150), Anniversary Series (SCM50/100/150) and Classic Series (SCM20/50/100/150), the SH25-76S is ATC’s premium 25mm soft dome tweeter, developed with a no-compromise engineering approach in order to complement the renowned SM75-150S Super Soft Dome mid-range driver.
https://scontent-lht6-1.xx.fbcdn.net...32&oe=58E61217
http://www.atcloudspeakers.co.uk/wp-...er-web-res.jpg
ATC Super SH25-76S HF unit & ATC SM75-150S Super Soft Dome mid range drive unit used in SCM150ASL Professional monitors
https://scontent-lht6-1.xx.fbcdn.net...46&oe=58D97291
http://atcforums.co.uk/product%20ima...Units%2010.jpg
ATC SB75-375(SC) SL bass unit used in SCM150ASL Professional monitors
Thanks
Rick @ Musicraft
From 1st April 2017, the vast majority of ATC products will increase in price by 8%.
Thanks
Rick @ Musicraft
