what is the w electric valve number?
396A - here's a pair for $80 plus delivery https://www.ebay.co.uk/itm/2-Western...8AAOSw8b1aOYY~
10 bits is more than enough for a lot of recordings. The bit depth only determines maximum and minimum amplitude, not the frequency response. Also he measures the Topping DAC by the same parameters and gets 19 bit resolution. Which does tend to indicate that it isn't a fault with the testing equipment or procedure.
Chip in with Brian. ;)
They are certainly worth it, imo.
You won't have to bother with those others, Grant, if you invest in the WE.
New preamp - Herron VTSP-2.
6 EH ecc88 valves tucked away inside.
I think it goes rather nicely with my 2 Trigon monoblocks. :)
https://i.imgur.com/rFaKZ5E.jpg
Early days yet, only arrived this morning, but I'm really enjoying it!
