No probs with loosened wood fibres as long as the surface is prepared well first. No sanding required between coats, although one coat is often enough.
It's touch dry within half an hour and a second coat can go on within an hour. Application of good wax finishes the job.
Simply apply following the grain and any excess that goes over edges can be wiped off with a finger without leaving marks.
I used to french polish cabinet work, but this is easier and looks every bit as good.
