** A simple step-by-step guide showing how to include pictures in your ads **
[Note this has been copied from Alex’s thread in The Gallery section].
It seems that linking to photos is a constant source of problems for some of our members, so I thought I would put together a step-by-step guide to expand on the instructions already put together by Rob.
First of all - let's look at how you can link to any image or photo that is already on the web.
You need the link to the actual IMAGE and not the web page. (If you are using Google Images as a search, be sure to click through to the full image and not just the thumbnail in the search window, otherwise you will just link to the low resolution version.)
In Microsoft Internet Explorer, right-click the image you want to include in your post, and choose "Properties" and then highlight and copy the link for "Address (URL)" half way down the pop-up box that appears, and then close the Properties box. Highlight by clicking and dragging the mouse over the whole of the link until it is highlighted black, then right-click and select (left click) "Copy"
https://i.imgur.com/n21ynSP.jpg
With Google Chrome it is easier - just Right Click the image you want to link to, and then choose "Copy image URL" from the drop-down.
https://i.imgur.com/teL4X1P.jpg
The principal is the same with Mozilla Firefox - but this time the option is called "Copy Image Location"
https://i.imgur.com/a6rKrGG.jpg
Whichever browser you use, you should now have the URL of the image copied to your clipboard, and you are now ready to include in your AoS post.
The easy way is to use the "Image" button. Make sure the cursor is where you want the picture to appear in your post screen, and click the button - this will create the "tags" that tells the forum software you wish to display a picture.
https://i.imgur.com/6JRJ8on.jpg
A small window will appear - right-click the text and choose "Paste" to paste the link you copied earlier.
https://i.imgur.com/XPdaNa6.jpg
Click "OK" and the system will automatically place the code in your post, be sure to move away from the highlighted text or you will delete it.
https://i.imgur.com/ReTfRHK.jpg
So - in practice, all you do is press the Image button, and then paste the link where you want the picture - job done!
You can also just type the IMG "tags" directly on screen (as they appear above) if you're feeling confident...
When you complete your post, the Image will appear where you have placed the text - easy!
Uploading Your Own Images to Photobucket
If you want to put photos of your own in a post, you first need to get them onto the web. Although you can "attach" a photo directly to the forum, this only includes a thumbnail in the post and it looks a lot nicer just to include the whole picture. To enable you to link to a picture, you need to upload your own photos to a free image hosting site such as Photobucket. (Others are available, but I personally think Photobucket is the easiest.)
http://photobucket.com/
You will need to create an account if you don't already have one - this is straightforward, and you should just be able to follow the instructions on the site. Then, it is time to upload your own pictures. Try to keep these to a small size - I'd suggest no more than 1000 pixels wide - you can use Photobucket to resize the photos if needed once uploaded.
https://i.imgur.com/RMZdAc8.jpg
You might want to create a new album especially for the purpose - click the New Album button - which will give you this screen: By default it sets the view to "Public" - make sure you don't change this, otherwise the images won't appear on the forum.
https://i.imgur.com/zCgwVrT.jpg
Once you've created your new album, you now need to choose the photos to upload. Click the big green "Select photos and videos" button
You will then get a standard Folder viewer - navigate until you find the folder where your photos are stored, and then click the image you want to upload. If you hold down the "Ctrl" button, each image you click will be added to the upload list, so you can upload multiple photos in one go.
https://i.imgur.com/kz2DSiv.jpg
Once you are happy you have selected all the images you need, click the "Open" button and the photos will begin to upload.
https://i.imgur.com/yl5pa4y.jpg
Once your photos are stored in Photobucket, it is then simply a case of "linking" to them in your forum post, in the same way as we did at the beginning of this tutorial. In Photobucket it is even easier, as you can copy the whole "IMG" code, including the URL and the Tags: All you do is click the "IMG Code" you see under the photo in Photobucket - it will briefly show "Copied"
https://i.imgur.com/yM8MgFD.jpg
All you need to do now, is just paste the copied text into the forum where you want the image. (Just put the cursor where you want the picture, and then "Ctrl" and V or right click the mouse and choose "Paste") - you don't need to worry about the Image button, as Photobucket has already created the code for you when you copied it. Job Done.
I'm happy to try and help further if you are still having trouble - drop me a PM and I'll do my best.
In the meantime - happy pasting!
Alex.
Posting images from Flickr
Despite rumours to the contrary, posting photos from Flickr is perfectly possible if they are on your account. If you're having difficulties this may help.
It is much more complicated that it used to be but basically go to the ‘share’ icon for the photo you want to post and choose ‘HTML embed’ from the share menu. Choose the size you want and then copy the code in it's entirety:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/125938826@N08/20451926589/in/photostream" title="Moode alsamixer"><img src="https://farm1.staticflickr.com/774/20451926589_32fff9c9cd_c.jpg" width="800" height="469" alt="Moode alsamixer"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
From the code pick out the ‘farm’ URL – from https up to and including .jpg as in this example
https://farm1.staticflickr.com/774/2...fff9c9cd_c.jpg
Then use the insert image facility in the AoS message box to post the URL – this will add your image to the message
Putting photos on from Cubeupload
Gents I am trying to put some images on with a post but they are way to big when I preview the post
You only get a section of the image with the rest off the page
I cannot see how to shrink them to fit
I am just clicking the insert image button and copying the URL over and it shows in the preview but massive
Any thoughts
Thanks in advance
Shaun
**** A simple step-by-step guide showing how to include pictures in your ads ****
Don't know imagur but is copy the correct command? Share may be. Then it has the img to be wrapped around it. Ive always used imageshack and never had an issue with them. Currently using flikr as well now as a cloud to save my photos as I want to keep them safe and get them into albums etc. I believe you can use it for hosting but don't know the ins and outs of it.
If stuck, pm or email me the pics and I can add them to your sales thread
