6J1 Pre-amp modifications (hum removal)
As bought from here:
http://www.ebay.co.uk/itm/2917862715...%3AMEBIDX%3AIT
https://www.qiannipicture.com/pic/up...9BCC56A0CD.jpg
As standard there is a low level hum present, this is cured by fitting an extra capacitor. You need a 470uF 35V electrolytic, the NEGATIVE lead is connected to the junction of two 47 ohm resistors on the top of the board as shown below:
http://i601.photobucket.com/albums/t...r/P1030658.jpg
The POSITIVE lead is wrapped around the side of the board and connected to the 0V or 'earth' connection of the input sockets:
http://i601.photobucket.com/albums/t...r/P1030659.jpg
Modification to covert to a buffer stage.
The circuit of the board is this:
https://www.circuitlab.com/circuit/9...shot/1024x768/
...although the 100K output resistors are actually connected to 0V not -28V as shown.
To alter the function from a gain pre-amp to a zero gain buffer stage the circuit is altered so:
http://i601.photobucket.com/albums/t...r/P1030667.jpg
Three new components need to be added to give the correct valve biasing. 2x 150K resistors and a 1uF decoupling capacitor.
The two 4.7K anode load resistors are removed from the centre of the board and replaced with wire links:
http://i601.photobucket.com/albums/t...r/P1030660.jpg
Replace the two 220 ohm cathode resistors with the two 4.7K resistors just removed.
The two 1uF output capacitors have the front leads lifted from the board (closest to the volume control), then extended and connected to pin 2 of each valve, shown below:
http://i601.photobucket.com/albums/t...r/P1030662.jpg
The extra biasing components are fitted to the front of the board once the two 470K grid resistors also have their front leads lifted from the pcb.
The connecting points can be seen in this photo:
http://i601.photobucket.com/albums/t...r/P1030661.jpg
Job done :)
Further modifications to the 6J1 pre-amp
Having tried this now in various guises; gain stage - triode and pentode operation, buffer (cathode follower) operation, and finding very clean and transparent performance, I have added a couple more valves to try and give some 'tubiness' to the sound.
I have fitted a couple of 6418 miniature pentodes, wired as triode gain stages before the 6J1's in buffer configuration.
Looking at the spec sheet for the 6418 they show quite a lot of harmonic distortion, but listening through it gives a very satisfactory sound at typical CD levels.
http://i601.photobucket.com/albums/t...r/P1030677.jpg
I think it's possibly what you wanted now Oliver :D
