:rolleyes:
:rolleyes:
I got pulled for it back along, its only fair we all play by the same rule book Martin. I know you are called Martin because it says 'I'm Martin' in the corner of your post.
See, the system works.
What about those of us that use our name as our avatar?
Well, I was in that group but seemingly it wans't enough. I now understand there are those who need to see the name in the top corner so there should be uniformity to cater to the lowest common denominator.
I think that was the general consensus - if you use your name in your username, and/or your signature, then it isn't quite so important, but if people are worried about it and can't figure out who I am I'll gladly change mine.
(IfMarcoTellsMeTo... ;))
As in life, there are certain motivators and enablers that implore us to act. The same can be said for here.
Yeah, simple rule, chaps: if your username and/or your signature contains your 'real' name, then the 'I'm' bit on your profile can contain anything (polite) that you wish!
Basically, as long as your real first name is featured somewhere on your posts on the forum, you're ok, but if your username is 'Cyborg126534', and you have 'I'manalienfromouterspace' written on your profile, with nothing in your signature other than a 'famous' quote, system list, or some such, then you're NOT ok! ;)
