https://scontent-lhr3-1.xx.fbcdn.net...03&oe=5DF1CBB0
Musicraft's new Sugden Audio A21 Signature pure class A amplifier in Blue finish chilling out on top of the world's best subwoofer and the king of bass JL Audio's 4500w Gotham v2 -
https://scontent-lhr3-1.xx.fbcdn.net...0a&oe=5E611780
https://scontent-lhr3-1.xx.fbcdn.net...77&oe=5E5C2537
https://scontent-lhr3-1.xx.fbcdn.net...db&oe=5E49B60A
https://scontent-lhr3-1.xx.fbcdn.net...81&oe=5E51180F
https://scontent-lhr3-1.xx.fbcdn.net...bb&oe=5E5BFA16
https://scontent-lhr3-1.xx.fbcdn.net...8b&oe=5E55FDB0
https://scontent-lhr3-1.xx.fbcdn.net...74&oe=5E4A56D0
https://scontent-lhr3-1.xx.fbcdn.net...84&oe=5E1FBDE2
https://scontent-lhr3-1.xx.fbcdn.net...17&oe=5E18A2D2
https://scontent-lhr3-1.xx.fbcdn.net...40&oe=5E6419B3
https://scontent-lhr3-1.xx.fbcdn.net...a5&oe=5E529DA3
http://mediacdn.jlaudio.com/media/mf...jpg?1510189377
JL Audio's Reference Gotham® v2 4500w active subwoofer is at Musicraft (Derby)
The Sugden pure class A design provides affordable high-end performance from a beautifully engineered single box integrated amplifier. Compact in size with a simple but stylish design, the A21 is possibly the only amplifier you will ever need. With many of the original A21’s still in daily use after fifty years, it could also last a life time. Providing a large soundstage and depth to all types of music, the A21 is an amplifier you can listen to for hours without fatigue. The single ended voltage rail circuit provides impressive dynamics and incredible bass.
The A21 Signature integrated amplifier is available with or without a MM/MC phono input. Without a phono input it is designated the A21L (line input only). A21aL models can be fitted with a phono input at a later date.
https://static.wixstatic.com/media/1...6e795037ec.jpg
The company was founded by James Edward Sugden in 1967, a division of Research Electronics. Research Electronics manufactured scientific instruments and test equipment, designed by James Sugden, for Universities. The A21 was the first amplifier to be put into production and was originally branded for a well known local loudspeaker company called Richard Allan.
https://static.wixstatic.com/media/1...8773de9ce6.jpg
https://static.wixstatic.com/media/1...db6f1dfc3f.jpg
https://static.wixstatic.com/media/1...105437d658.jpg
https://static.wixstatic.com/media/1...375f54~mv2.jpg
Sugden Audio. The best of British.
Sugden Audio A21 Facilities -
• Inputs - Five line level (four on A21 Integrated), Optional mm/mc phono
• Outputs - One pair of stereo multi-way binding posts, Pre-out (variable), tape out (fixed)
• Remote Control - Volume up/down
• Earth terminal
Sugden Audio A21 Specifications -
• Line Input Sensitivity - 170mV for max. out
• Phono Input Sensitivity - 3mV/mm, 0.2mV/mc for max. output
• Phono Loading - MM 47K MC 100 Ohm
• Power Output - 23 Watts into 8 Ohms
• Frequency Response - +/-1dB 10Hz-20kHz
• Bandwidth - 6Hz-200kHz
• Signal to Noise - >83dB
• Gross Weight (packed) - 11kgs
• Dimensions - 92 x 430 x 350mm (hwd)
***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
