Hahaha, good one Kevin:lol:
But there are so many Youtube clips of the Technics, but they all relate to DJs. I put a couple of clips out, just to show that the 1210 is a hifi deck. But there are no videos of ETP platters or high end tonearms:)
How does one remove the speed sensor cog from the old platter, the magnet comes off easily but the cog looks like its been press fit.
I thought that the speed sensor had to be aligned to the magnet.
Every replacement platter I have had has always had this fitted.
Hi Andrew,
All will be revealed when you get the Platter and Base Plate together with the Instructions.
If you try to anticipate things then mistakes may occur.
The central pulse generator is not removable and stays with the platter.
Just bought a Analogue Crystal Mat (aka Nagaoka) as a xmas gift to daddy:eyebrows: Hope it will make the sound even better on top of the ETP platter...
1000 Krone says it will! ;)
Hehehe, good one Marco! Since you said it was so great I just had to get one. Not easy to find any more...
