I've not used these particular ones, but the improvement when I rebuilt my crossovers using Hovland MusiCaps was pretty spectacular, and they were already made with modern components.
I used the upgraded SA range made of very thick film for long life before the
M caps or ESR caps came out and they are a sonic blessing. I may chanhe them out to the ESR upgrade but the M caps are just to pricey.
http://www.madisound.com/catalog/pro...oducts_id=8146
http://www.madisound.com/catalog/pro...oducts_id=8121
http://www.madisound.com/catalog/prh...oducts_id=8370
http://www.madisound.com/catalog/pro...oducts_id=8629http://www.madisound.com/catalog/pro...oducts_id=8370
I linked all there caps from ceapest to OMG thats crazy!
ARC use Clarity Caps almost exclusively I think (they used to use Wonder Caps). I wonder if their designs would be as good as Glenns products if they used standard ones????????
Well, the Clarity Cap ESAs in my Croft Charisma-X don't seem to be doing it any harm, Dave... It's all about implementation, my boy! ;)
As an aside, here's an interesting article on capacitor comparisons:
http://www.humblehomemadehifi.com/Cap.html
I don't know if they have been proven better after all his highest rated cap is the Duelund copper.
I am happy with the Clarity Cap SA they did take some time to break in for the topend to open up but they use the thickist film on the market in there construction and I wont have to replace them in my lifetime.
They where known to have a low ESR when I bought them and in there price range nothing comes even close.
You must give them time to break in I left the speakers on at a low volume all night and while I was at work for over 2 months!
Bass got noticably tighter,the sound stage opened up as well as the top end but I have seen this before with Blackgates.
Black gates are odd when first installed they don't sound like much till around 400 hours then WOW!
ESA?
Equivalent Series Resistance (ESR)messured in ohms or in Clarity Caps miliohms.
http://en.wikipedia.org/wiki/Equival...ies_resistance
Hi
Dont know where the sonics blue caps come in the equation but, fitted some into the midrange crossovers on my goodmans horns ,they were utter crap,sounded grainy and distorted ,far worse than the out of spec 40 year olds they replaced .Fitted some cheap same value bennics ,far better.Cant come up with a suitable reason for this,but I persevered with these sonics in other cicuits tried them as coupling caps in a preamp with the same results, utter crap.In my opinion of course.
Dave.
