Help Help Help etc
First time in this part of the forum , Hello Digital people
YES it me Analogue Al :lol:
I have a Imac and have just signed up to Amazon Prime , that gives me access to 1 million tunes :)
I have also purchased a John Kenny Ciúnas DAC
I have found my midi interface on my Mac now what do I do , I have the correct cables in place to join it all up but no sound from my hifi using the aux terminals :scratch:
Help Help Help etc :)
The battery in the DAC is charged up I take it?
Yes it on charge ( Blue light showing ) :)
Test it by hooking up a cd player as a transport. Still no sound, finger points at DAC.
What are you doing pissing about with MIDI interfaces?
How old is the iMac?
It might have Toslink optical out of the headphone jack if it's one of the older ones.
try a mini toslink to toslink from mac(think the 3.5mm socket is also a toslink) and bypass the bit inbetween..OR It might be a interface problem. IE if I set my dac to anything bar 16/48 then spotify or amazon wont play so check the dac is set to 16bit/48khz
Its a late 2013 model purchased in 2015 as there were no updates
Which means that it's likely to have Toslink on board.
All you have to do is find out where to turn it on, and connect a Toslink (with appropriate adapter) between the iMac and DAC.
It has these connections :-
3.5mm headphone jack
SDXC card slot
Four USB 3 ports (compatible with USB 2)
Two Thunderbolt 3 (USB‑C) ports with support for:
DisplayPort
Thunderbolt (up to 40 Gbps)
USB 3.1 Gen 2 (up to 10 Gbps)
Thunderbolt 2, HDMI, DVI and VGA supported using adapters (sold separately)
10/100/1000BASE-T Gigabit Ethernet (RJ-45 connector)
Kensington lock slot
